B
BlackMax98
Guest
Hi All,
I have a unique problem and would like to model this using Pro Mechanica Thermal. The problem is as follows:
Scenario 1: I cyclinder is uniformly conducting heat through four layers of insulation and I would like to calculate the heat flux by conduction through each. The setup is like this:
Cylinder, Layer Insulation, Layer Insulation, Layer Insulation, Stainless Steel Envelope
All heat transfer is by way of conduction and all K values are known in W/m K. Can this be modeled in Mechanica??? If so, a walkthrough or tutorial would be much appreicated.
Once I get through this problem I will post a second scenario which is simply the same problem with a level of radiation transfer replacing one layer of conduction.
Thanks in advance for the help!!
Sabe
Sabe
