Thermal analysis of a heating pot
  • Thread starter Thread starter Raychar
  • Start date Start date
R
Raychar
Guest
Hello guys!
i want the analysis have the output the fringe plot of temperature on outer surfaces of housings. The conditions were set as in attached image. The outcome result is all these surfaces are at temperature 25 degree Celesisand itis not aligned with the actual case. The air which is between the housing and the metal container would be heated up, it conducts heat to plastic housing and also some of it will escape out from the grilles, i don't know how to specific these conditions in the analysis setting. Can someone get a help on it.
Thank you very much in advance.
raychar
