IvanZhidlovsky
Bioengineer
Generally, WTE facilities can be divided into two process types: mass burn and refuse-derived fuel (RDF). Mass burn facilities process raw waste that has not been shredded, sized, or separated before combustion, although large items such as appliances and hazardous waste materials (more ) and batteries are removed before combustion. In mass burn systems, untreated MSW is simply burned, with the heat produced converted into steam, which can then be passed through a steam turbine to generate electricity or used directly to supply heat to nearby industries or buildings.
RDF is a result of processing MSW to separate the combustible fraction from the noncombustibles, such as metals and glass. RDF is mainly composed of paper, plastic, wood, and kitchen or yard wastes, and has a higher energy content than untreated MSW. Like MSW, RDF is then burned to produce steam and/or electricity. A benefit of using RDF is that it can be shredded into uniformly sized particles or compressed into briquettes, both of which facilitate handling, transportation, and combustion. Another benefit of RDF rather than raw MSW is that fewer noncombustibles such as heavy metals are burned.
Does anyone know proper technologies that are used in the sphere?
