the original Mini was rather "tail happy"
Tmoose
Back in an aerodynamic drag downforce thread 87-253222 Greg Locock mentioned the original Mini was rather "tail happy".
The general chestnut offered is FWD cars understeer, so that sounds interesting.
Was that believed likely an aero induced thing, or perhaps related to semi trailing arm rear suspension, or ???
thanks
Dan T
I think that with two or fewer people inside, the real Mini was rather front heavy.
It might be more precise to say that the rear tires were hardly loaded at all until you put something in the rear seats.
Mike Halloran
Pembroke Pines, FL, USA
Yup, nothing to do with aero, everything to do with weight distribution. Same as the handling of light trucks. According to the schoolboy theory the lightly loaded end should have more grip. Ha.
Cheers
Greg Locock
So, Is this yet another area where the "new" Mini is no Mini at all?
For starters, it's half again bigger than a real Mini.
It's also comfortable, well-appointed, and quiet.
What fun is that?
Mike Halloran
Pure trailing arm suspension with very high spring rates (in the original rubber-spring design) in addition to not much weight on the back.
Greg L said "According to the schoolboy theory the lightly loaded end should have more grip. Ha....."
But, isn't that part of the commonly offered explanation of how anti-roll bars work? The more heavily loaded tire's grip increases, but not in proportion to the added load?
I have some first hand experiences that all seem to confirm stiffer roll bar increases the slip angle and even reduces the cornering force of the pair of tires.
