Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Interesting, I thought the W# came more from the nearest overall depth. The more you know.W shapes are rolled with a consistent inside dimensions between the flanges (maybe a couple inside dims per nominal depth), not a depth, so you'd expect a W14 with 6.5" inches to be somewhere around 20-22" deep
AI? Or Nucor employee?The NUCOR W14x1000 truly earns its title as the mother of all columns. With a staggering weight and unmatched load-bearing capacity, it's the go-to choice for heavy-duty structural projects where strength and durability are non-negotiable. Whether it's for skyscrapers, industrial facilities, or critical infrastructure, this column sets the benchmark. NUCOR’s engineering excellence is on full display with this behemoth—truly a marvel in modern steel fabrication and a testament to what's possible in structural design.
You're right. I prefer "veritably."Also, I don't know many adults who use "truly" that much.
