If grout under the base plate means there are leveling nuts beneath the plate, then anchor bolts can also act in compression. This would change he load distribution below the plate, and could certainly affect the base plate thickness. Normally the anchor bolts are ignored on the compression side. I would think this is conservative, but don't know for sure.
