The Doc say: <OutAttribute> [b]ByRef[/b] item_type As String How to declare this in vb
Ehaviv
Computer
IL
Hi
please help understand the uf_ref doc.
the doc say:
<OutAttribute> ByRef item_type As String
how I declare this in vb journal ==>> ( Dim ByRef item_type As String ) ?
Because ==>> Dim item_type As String this not work.
Code:
UFClone.AskItemType Method
Wrapper method for UF_CLONE_ask_item_type
Public Sub AskItemType (
	input_part_name As String,
Code:
   Dim item_type As String  <<== Not works
   Dim s As Session = Session.GetSession()
   Dim ufs As UFSession = UFSession.GetUFSession
   Dim input_part_name As String
   Dim ByRef item_type As String    <<== (ByRef) Do this possible
  ufs.clone.AskItemType(input_part_name, item_type)
Shortly
This throw compile error keyword not valid
and this not work
( Return item_type = null <<== ufs.clone.AskItemType(input_part_name, item_type) )
Thank you.
The "OutAttribute ByRef" just means that the method you are calling is going to modify the value of that variable; it will essentially become the output of the method. You declare the variable normally, but note that its value will be modified by the method.
Code:
Dim input_part_name As String = "some input part name"
Dim item_type As String = ""
After the code runs, the "item_type" variable will contain the item type of the given input part.
www.nxjournaling.com
Cowski
I'm very much thank you
Because I have understood and did as you posted.
But askitemtype (current clone operation part name, part item type) in my journal
Iteration always return null.
The assembly that I iterated have some items types.
Please can you give me a clue why so.
I'm very much thank you.
Hi ufsure and thank you.
Yes I know that.
So
What happened if I remove the
This statement
ufs.Clone.SetDefItemType("")
Then what will the default.
My clone operation is clone some components
And retain the rest.
And for them I set the above default
Statement.
Another question
If I have this
And I use also this
ufs.Clone.SetItemType("some type")
Is this statement do nothing
Because of the previous statement.
Hi ufsure.
After rereading the doc
And deeply thinking
I come to feel that you are right.
Tomorrow I will have access to nxmanager
And I will test it.
Because immediately after the statement
Nx set all the parts in the clone operation
To item type null.
And when I asked the item type for
A part i get null and that makes
My journal to go wrong.
Hi
I'm disappointed.
I removed ufs.Clone.SetDefItemType("")
From my journal.
and still I got null in askitemtype
Do someone have a thought about
This.
Why askitemtype always return null.
Thanks in advanced.
Hi ufsure and thank you for your wanting to help me.
'The code wrote in my company and I can not bring it out from company. (restriction issue)
'but this is the relevent recoded for the problem issue
Dim pnItemType As String = Nothing
Dim addAssemblyPart As String = Nothing
ufs.Clone.Terminate()
ufs.Clone.Initialise(UFClone.OperationClass.CloneOperation)
Dim status As UFPart.LoadStatus = Nothing
ufs.Clone.SetDefFolder(":Cloned Parts")
'ufs.Clone.SetDefItemType("") ' with / without this still return nothing
'ufs.Clone.SetDefItemType("som_string") ' I tryied this and still return nothing
addAssemblyPart = "@DB/" & display_part.FullPath
ufs.Clone.AddAssembly(addAssemblyPart , status)
ufs.Clone.SetDefAction(UFClone.Action.Retain)
ufs.Clone.SetLogfile("c:\clone_log_file.txt")
ufs.Clone.StartIteration()
Do
ufs.Clone.Iterate(prt_name)
If(prt_name = Nothing) Then Continue Do
If prt_name.Contains("/specification/") Then Continue Do
ufs.Clone.AskItemType(prt_name, pnItemType) ' this alwaisreturn nothing
If pnItemType = "UserPart" Then
ufs.Clone.SetItemType(prt_name, "UserPart")
else
ufs.Clone.SetItemType(prt_name, "ExtPart")
End If
Loop While (prt_name <> Nothing)
Dim faile As UFClone.NamingFailures = Nothing
Try
ufs.Clone.PerformClone(faile)
Catch e As Exception
lw.WriteFullLine("NX Exception = " & e.ToString)
End Try
'I replaced these statements:
else
End If
'by this statements:
'To check if SetItemType works and indeed works
Code:
   Do
     else
     End If
   Try
   End Try
   else
   End If
Note that the complete journal
Works as expected.
Except that it's recording the wrong
Item type. ( Not the one I want )
I'm thank both
For training to help me.
I'm thank both
For trying to help me.
I'm thank both of you.
Sorry ny English
Is not my first language.
