Texture (Decal) Bleeding
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
I created a color with a decal. I applied the color to the surface of a part. The decal shows up great on the part. However, when I put the part into a large top level assembly, the decal bleeds over every thing else.
Any solutions on how to get rid of this bleeding?
The decal where it's supposed to be:
The decal where it's not supposed to be:
Jason -
A couple of thing to check -
1) did you apply the decal in assembly mode? This can lead to strange things happening. Better to apply appearances in part mode.
2) did you change the file format to decal (ie .tx1 or whatever the extension is) or did you apply a .jpg or other picture format directly? Sometimes changing the format helps
you might want to check www.3drender.com for more info :)
oh, one more thing. if you are positioning or re-arranging your scene within the photo render menu it helps to exit photo render menu and re-enter it. Sometimes I think pro/e gets lost
Jason,
Saw a presentation at the Conference by John Randazzo, he suggested offsetting the surface that you want the decal to be on to eliminate the bleeding. Only needs to be a couple thousands offset then apply the color to that surface. Maybe this will work for your application?
