text file in V4 drawing
matt22dsweet
Automotive
FR
How can I include a text file which contains more than 80 characters per line?
Thank you for your help.
when you are inserting text, on the menu bar there is a number with carriage return arrow going thru it.
The number its set at, and if its highlighted (selected) represents how many blank lines you get every time you
enter text.
What you need to do is dehighlight (unselect) that selection box. Then you can add more text to the same line.
you will still be limited to the 80 characters before you have to hit enter, but then you can continue in the same line of text (subtext).
Then when you want to go to the next line reselect the menu pick with the number in it.
Hi matt22dsweet,
It has already been a thread in COE discussing this:
Just put the abstract in here:
"alias M1000 =
catia.REPORT = '/foldername' ;
CATIA.RECORD_LENGTH.M1000 = 132;
It's found that 132 is the maximum length possible for TEXTD2 FIL
cheers. Kennis Tang.
Hi Kennis,
I've set the CATIA.RECORD_LENGTH.M1000 to 132 but I don't know how to create a 132 characters txtn in TEXTD2 function. Is there something to change in the TEXTD2 standard?
My objective is to import a .report file on a drawing via an IUA macro.
Actually, each line of my file is truncated at the 80th character.
I'm thinking that if I understand how the TEXTD2 function works, the IUA will work too.
Matt
Hi rickyt,
Thank you for your response but I wouldn't like subtext
Hi Matt,
Well, the Record_Length declaration works for TEXTD2 FIL as well as batch utility, but not for interactive TEXTD2 which I believe still gets the Max Limit of 80 characters per line. (Remark:using /quitxt can have 1024 characters in one line)
So if I could suggest to check whether the declaration is properly declared or not by typing in the prompt :
catpath -l -A catia.record_length.*
Cheers. Kennis Tang.
Hi Kennis, Thank you very much. Finally I've chosen an other method to get my file. I've split it in several files of 80 characters and I've pasted them in catia with an IUA macro. Matt
