We are in the process of getting UL Recognition on one of our power converters, and are required under UL1741/UL2200 (unless I have misinterpreted it) to demonstrate that the equipment remains safe when short circuits are applied across individual semiconductors and capacitors.
The problem with this is that some of these short-circuit tests will write-off the alternator that feeds the power converter, and we could get through quite an expensive amount of hardware.
Has anyone else come up against this problem? Presumably, if say a 500MW system were being tested, it would be unreasonable to expect the manufacturer to damage the alternator as part of UL testing - are compromises common?
