acrockett
Nuclear
- Jan 15, 2012
- 3
The design i am working on uses a shear pin to avoid damging the equipment (in fault scenario). In order to commission the equipment we are testing a singe hsear pin to see what the failure load is. However, we are unsure if a single test is sufficient for testing shear pins. Can anyone provide some guidance on the testing of shear pins (i.e. what is best practice?). I have had a look and it seems we should expect variations of upto 15%, but for our shear pin do we nee to test a certain number of times over a full range of tolerances?
Andrew
Andrew
