SAE-AIR is an entire series of aero-related documents; below are the ones I have PDFs of
SAE AIR 1064C Brake Dynamics.pdf
SAE AIR 1075A Barometry for Altimeter Calibration.pdf
SAE AIR 1093 Numeral, Letter and Symbol Dimensions for Aircra.pdf
SAE AIR 1102A Transparent Area Washing Systems for Aircraft.pdf
SAE AIR 1106A Some Factors Affecting Visibility of Aircraft Navigation and Anticollision Lights.pdf
SAE AIR 1151 Flight Compartment Glare.pdf
SAE AIR 1168-1 Thermodynamics of Incompressible and Compressible Fluid Flow.pdf
SAE AIR 1168-10 Thermophysical Characteristics of Working Fluids and Heat Transfer Fluids.pdf
SAE AIR 1168-13 Spacecraft Equipment Environmental Control.pdf
SAE AIR 1168-14 Spacecraft Life Support Systems.pdf
SAE AIR 1168-2 Heat and Mass Transfer and Air-Water Mixtures.pdf
SAE AIR 1168-3 Aerothermodynamic Systems Engineering and Design.pdf
SAE AIR 1168-4 Ice, Rain, Fog, and Frost Protection.pdf
SAE AIR 1168-5 Aerothermodynamic Test Instrumentation and Measurement.pdf
SAE AIR 1168-6 Equipment Components, Equipment Cooling System Design, and Temperature Control System Design.pdf
SAE AIR 1168-7 Aerospace Pressurization System Design.pdf
SAE AIR 1168-8 Aircraft Fuel Weight Penalty Due to Air Condi.pdf
SAE AIR 1168-9 Thermophysical Properties of the Natural Environment, Gases, Liquids, and Solids.pdf
SAE AIR 1221 Electromagnetic Compatibility (EMC) System Design Checklist.pdf
SAE AIR 1608 Estimation of Total Error in Altimetry.pdf
SAE AIR 1609 Aircraft Humidification.pdf
SAE AIR 1657A Handbook of Hydraulic Metric Calculations.pdf
SAE AIR 1667 Rotor Blade Electrothermal Ice Protection Design Considerations.pdf
SAE AIR 1678 Uncertainty of In-Flight Thrust Determination.pdf
SAE AIR 1703 In-Flight Thrust Determination.pdf
SAE AIR 1758 Limits and Fits - International Metric Tolerance System.pdf
SAE AIR 1780A Aircraft Flotation Analysis.pdf
SAE AIR 1812A Environmental Control Systems Life Cycle Cost.pdf
SAE AIR 1823A Engineering Analysis System (EASY)( Computer Program for Dynamic Analysis of Aircraft ECS.pdf
SAE AIR 1845 Procedure for the Calculation of Airplane Noise .pdf
SAE AIR 1855A Actuation System Data Summary for Missiles and Launch Vehicles.pdf
SAE AIR 1939 Aircraft Engine Life Cycle Cost Guide.pdf
SAE AIR 2000E Aerospace Fluid System Standards.pdf
SAE AIR 4013A Multiplex Data Bus Networks for Mil-Std-1760A Stores.pdf
SAE AIR 4015A Icing Technology Bibliography.pdf
SAE AIR 4092A PTFE Melt Phenomenon for High Pressure Hoses.pdf
SAE AIR 4093 Compendium of Gas Properties R(1994).pdf
SAE AIR 4094 Aircraft Flight Control Systems.pdf
SAE AIR 4298 Impulse Test Machine.pdf
SAE AIR 4359 Effects of Hanging Loads.pdf
SAE AIR 4367 Aircraft Ice Detectors and Icing Rate Measuring Instruments.pdf
SAE AIR 4548A Real-Time Modeling Methods for Gas Turbine Engi.pdf
SAE AIR 4827 Modeling Techniques for Jet Engine Test Cell Aer.pdf
SAE AIR 4845 FMECA Process.pdf
SAE AIR 4911 Requirements Document for Sensor--Video Intercon.pdf
SAE AIR 5006-2 Volume II Probabilistic Design and Analysis Methods for Solid Rocket Boosters.pdf
SAE AIR 5020 Time-Dependent In-Flight Thrust Determination.pdf
SAE AIR 5022 Reliability and Safety Process Integration.pdf
SAE AIR 5080 Probabilistic Methods into the Design Process.pdf
SAE AIR 5086 Perceptions and Limitations Inhibiting the Appli.pdf
SAE AIR 5109 Applications of Probabilistic Methods.pdf
SAE AIR 5145 Directory of Databases Part I - Whole Body Anthr.pdf
SAE AIR 5396 Characterization of Aircraft Icing Conditions.pdf
SAE AIR 5689 Light Transmitting Glass Covers for Exterior Aircraft Lighting.pdf
SAE AIR 809 Metal Dimensional Change with Temperature.pdf
SAE AIR 818D Aircraft Instrument and Instrument System Standards.pdf
TTFN (ta ta for now)
faq731-376 forum1529 Entire Forum list
