vulcanhammer
Geotechnical
One of the curious things I have noted in classical sheet pile design is the fact that treatments of Terzaghi's techniques to analyse braced cuts and the strut loads generally insist on the hinge method to analyse the sheet pile wall itself, i.e., to assume hinges at each strut location except for the uppermost.
Except for the fact that this renders the sheet wall statically determinate, there seems to be no reason to do this. The wall itself is certainly not hinged at the supports; it's probably best modelled as simply supported.
Hoping to get some answers by going back toward the source, I took a look at Terzaghi and Peck (1948), but this simply states the following: "At the elevation of each strut except the uppermost, the piles are assumed to be hinged, and at the bottom of the cut they are assumed to bear against a knife edge." And that's about it.
Any thoughts on this?
