rvenzon,
I think you have provided enough to work with.
Datum A is irrelevant, because you are not calling it up.
By the sound of it, Datums G and F are non-parallel surfaces. These locate your part in two orthogonal displacement axes, and three rotational axes. You need positional reference for your tertiary datum.
The compound datum B and C does not make sense. Your tertiary locator would be a diamond pin picking up
either B or C. Picking up both of them controls side to side displacement and rotation. Your datum F already controls rotation.
You could use B-C as a secondary datum and F as your tertiary. That would make sense to me, although it is a horrible fixturing procedure.
GD&T datums are fixturing specifications, not dimensioning references. Most of your FCFs should specify the same datums. Is is the drafter using different datums for each face of the part?
Also, I think the MMC on the Ø.007" positional tolerance is hardly worth the trouble. I do MMC on features with sizes that are sloppy in comparison to the positional tolerance.
JHG
