Terramodel Blocks
DRJORDAN
Is it possible to explode a Terramodel block and use it in autocad?
If the file that you are trying to insert is a unit block, then try to insert the block into TerraModel, and export the drawing to AutoCad. You can then open the drawing in AutoCad, and explode the block as you would with any other block.
