It looks like this thread sorta got away from the original question, but now that the metric system has been brought up, I'd like to weigh in on that as well.
The problem with that system is that you never know which version you are going to be confronted with. Around 1960 this committee got got together and decided that the MKS (meter, kilogram, second) system wasn't good enough, so they expanded it to what is now called the SI (System International).
So now, you may have a bending moment that you had converted into kilogram-meters, and you are suddenly confronted with this thing called kiloNewton-meters. Now you'd think that they would have just made 1 kiloNewton = 100 kilograms, but no, you've got that little thing called gravity acceleration in there (to make a kilogram of mass equal to a kilogram of force), so it ends up being 101.97 kilograms. And don't even get me started on expressing psf in kiloPascals (kPa).
The bottom line is, both systems are purely arbitrary as to where you start, such as King Henry I stating that a one yard measurement would be the length of his arm. We in the US would have been much better off by adopting a decimal system throughout. Instead of making a foot = 12 inches, it should have been 10 units of something, similar to what is used in surveying where a 100 ft tape is broken down into tenths of a foot.
Basically, your favorite system will be the one that you were brought up with and are used to.
