Termination of lithium in lithium batteries.
asimpson
IE
I am doing some research on different electrical cells.
The electrode on a lithium cell seem to be made of an inert metal which passes through case and is connected to Li with some sort of paste. Would I be correct in assuming this is a conductive paste used to prevent any galvanic reaction between electrode metal and Li but still allow good electrical contact.
What would this material be?
Any other methods of terrminating Li?
I could be wrong, but I believe all of the lithium-based batteries put the lithium in the electrolyte, not the electrodes themselves.
Dan - Owner
My question is concerning the connection between Li and terminal.
I assume Li cannot be terminated outside battery chamber as it would corrode in air. Therefore a non corrosive metal must be terminated inside chamber.
How is Li connected to terminal? Is soldering possible?
Have you looked at references of the Wikipedia article:
TTFN
faq731-376
7ofakss
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com:
Thanks .
More complicated than I expected. Quite a vriety of possibl Li forms in cathode.
