We are designing a large swimming pool, for lack of a better description, where the walls of the pool are a fabric membrane that contains the fluid. The pool is on the order of 10' deep. Without going into the specifics of what the supporting structure is, I'm having nightmares about solving membrane problem. The membrane is wrapped around a support at the pool base and pool top. The membrane goes over these top and bottom supports, turns a 90 degree turn, and is then attached to a "fixed" support. Directly between these two top and bottom points is a roller, that prevents the membrane from bowing out in one big bulge. With the roller, it now bows out in two varying sized bulges.
The supports are steel pipes that span between larger, primary structure.
I have attached a sketch to clarify.
I am trying to size the supports (top, roller and bottom)without buying a non geometric linearity FEA modeling program, or by performing matrix analysis. Any suggestions on how to simplify this, or a hint on a cheap cable modeling program would be great.
