Hello All,
I know that one is not supposed to use tension-only bracing in seismic zones D and above (4 and above in the UBC). However, I can not seem to find the particular section of the code where this is addressed.
Does anyone have a reference to this? And also what portion of the bracing force needs to be resisted by compression in the bracing members?
I believe the rational behind this is related to the Northridge earthquake and its after effects but any light that can be shed here would be much appreciated also.
Thanks in advance,
JS.
Thanks in advance,
JS.
