Hi there,
I am placing a new spring loaded tension arm to replace the old one in a belt drive. This tension arm will also be in a different location than the old one. I am concerned that placing the tension arm right before a wheel with a skinny shaft might cause it to bend. Is the tension in the entire belt constant or does it vary from section to section.
Thanks for your help
