enve2014
- Aug 21, 2014
- 7
I’ve been tasked with designing a temporary water pipeline to transport 10,500,000 gallons of water from a river to a tank approximately 1.7mi away. The elevation difference between the river and the tank is approximately 180ft. The height of the tank is 66ft. I’ve calculated a head loss due to friction of approx 153ft. Therefore a TDH of approximately 400ft (I believe this is correct).
Pump selection is not my strong suit, but we would like to run 1 main pump with 2-3 booster pumps along the line at low pressures. I’m wondering if this would be necessary, and how I would go about determining this.
Also, has anyone used a sediment removal system at this high of a flow rate with any success? We’ll be using 8 inch Victaulic coupled line.
Any thoughts or insight would be very helpful.
