Temporary shoring for residential brick veneer
foleyt
How does one temporarily shore a veneer brick wall from the outside while installing a 14 foot lintel.Lintel to be installed at same elevation as second floor floor joists.Wood framing to be carried independently.Veneer height above lintel 6'-6"
I've bolted a continous angle to the wall about 8" above the new opening with expansion anchors in the mortar joints, and used 4x6 posts at a slight angle down to temporary footings in order to support the angle, and brick above.
