Hello!
I have some questions about temperature in pressure vessel.
Suppose that I have pressure vessel which operation (or design - it doesn`t matter) loads only P, Ps, D and T.
to evaluate the vessel I use elastic-plastic analysys acc. ASME VIII div.2 part 5.
So I should use load combinations from table 5.5. They are:
1)2.4*(P+Ps+D)
2)2.1*(P+Ps+D+T)
3)2.1*(P+Ps+D)
*cases with P=0 we will not consider for simplification
Questions:
a) Can I don`t consider the third combination because 2.1<2.4 ?
b) Should I use material properties according temperature = T even there is no T in load case?
c) Why is T in only one load case although P can`t exist without T as a rule.
Thanks!
1)2.4*(P+Ps+D)
2)2.1*(P+Ps+D+T)
3)2.1*(P+Ps+D)
Questions:
Thanks!
