Carlbauer
You appear to have metastable soils and micro climate problems similar to what I experience. My dessicated, metastable soils my be up to 25 - 35 feet (8-10 m)thick and are usually underlain by expansive Shales and Mudstones. I have adopted a scheme of overexcavating, watersoaking (if site conditions allow) and replacing with Structural Fill, usually Native Soil. One of my goals is to change (usually increase) the foundation soil moisture environment to match the later service conditions. The water soaking must be done carefully, in order to avoid problems to nearby structures. There are a lot of subtle and not so subtle factors to consider when soaking.
I prefer to use a low plastic, clayey soil for final, upper backfill around the foundation. I have found this tends to 'shed' the surface runoff and reduces later, deep soil moisture increases.
To put some of the previous suggestions into perspective, we need to consider:
First, the SPT test assumes the soils are reasonably moist to nearly saturated. The Plate Bearing Test assumes the soil moisture conditions of the test are similar to the service conditions. For me, these conditions are usually unrealistic.
Next, what is the actual service conditions of the structure? Such as, will the foundation soils generally gain or lose moisture? What reasonable, total depth of soil moisture change can be expected? Can I postulate 'levels' of potential settlement?
Next, Time for reasearch. Modify a 'test' site by overexcavating, water soaking (if appropriate), densify the subgrade and replace with a fill. Then either drill and get very good sanples or carefully test pit (or completely excavate the improved soils out)to obtain densities and good samples and then laboratory testing. How effective was the soil improvement?
Then modify the soil treatment, as required.
Remeber that the structural fill begins to interact with your foundation and the whole behaves like a MAT Foundation. The total potential settlement can still be fairly high, but the differential settlement is usually dramatically reduced and structure servicability is usually maintained. Reinforcement of the structural fill with layer(s) of a Geotextile or Geogrid Product can also be very effective to creating your 'structural unit'.
At this point, the SPT testing may be corrolated for this soil type/moisture condition. I belive that in-situ soil density will be more helpful, especially if you are able to accomplish consolidation/collapse testing.
Sounds like a lot of work. I just went through this for residential construction design recommendations. Home Owners in the U.S. tend to water a lot and cause enormous problems. The grass must be very green!! We were pleasently surprised at the amount of actual improvement which could occur by our treatment and we have been able to create a corrolation with in-place soil density (Shelby Tubes and possible down hole nuclear densitometer) rather than the SPT, which is always high due to our dessicated soils.
Keep us posted with new information and your suggestions.
