Technical Term for Bolt Backing Out? 4
JakeAdkins
Is there a more technical way of saying that a bolt is backing out?
I am writing a service bulletin and want to let the customer know that a bolt tends to back out over time.
There are quite a few (self-claimed) bolt locking devices (anti backing due to vibration). You can do a web search to find out.
Nordlock washers work very well. There is also this stuff called "Loc-Tite". Sorry, too much sarcasm for this late in the week. :>)
Adalius-
We have found that lock wire doesn't really work as a retention device but more like an indicator (if lock wire is broken you bolt is loose.
Nordlocks do work very well but I don't have the counter bore.
And besides, Jake indicated earlier that a permanent fix had been designed.
I've used Nordlocks before, I thought they were an incredibly simple yet deviously smart solution.
I must admit I'm surprised you say you've had lock wire breaking from it backing out only under vibration, though, unless these are fairly small fasteners and thereby requiring a small diameter lock wire. Granted my experience mainly lies in gas turbines in regards to lock wire so you're talking a minimum of 1/8" wire.
In any event, as you said you found a permanent solution so its a moot point, I was just throwing a brain dropping out as curiosity often gets the best of me.
I like
That says it all!
Bill
"Why not the best?"
Jimmy Carter
IRstuff...yes..loosening can come from elongation of the bolt, creep, fatigue, etc....none of which are necessarily rotation.
