netzen
- Dec 8, 2009
- 5
I ran into a problem that need to use a 1:10 taper stud / bore connection to transfer loads, the smaller end of the taper is ~1.0" and the entire engage length is 1.125".
The stud is conical shaped and made out of hardened steel and material (cast iron, grade, etc.) on the female part is yet TBD. Very typical configuration if you've seen a tie rod assembly used a lot on automotives
could someone recommend a calculation method to estimate the joint fatigue capacity based on a certain loading?
I've originally posted this under Structural Engineering forum then was told more help might be available from this forum.
Thx a lot!
Thx a lot!
