Taper Boring of Fittings
ilkin014
Materials
AO
HI All,
Could you please advise me,
which types of metallurgical affects has a taper boring on fittings/flanges (for Carbon and Stainless Steels)?
(For example if we are going to reduce wall thickness up to 10mm?)
Ilkin HASANOV.
I don't understand the question.
Taper boring is a machining issue where if you lubricate the cutting element, there is no impact.
10mm sounds like a lot though. Most flanges have min and max bores which may not accomdate that much.
Ilkin014,
Look up the flange/fitting standards and see what is the minimum required thickness. Simply put, going below the required thickness is not acceptable unless you want to spend expensive engineering analysis.
GDD
Canada
