Tap drill depths for spiral point plug tapping blind holes.
For over 40 years I have waited for a definitive formula that would work well for calculating tap drill depths for blind holes. For 30 years I have used the simple formula of Thread Depth + Thread Pitch * 9 for threads of two diameters of depths. This works in most cases and is far better to use than the Blah, Blah Blah, espoused by so called machining, (usually self elevated), experts.
The fact is the volume, stiffness and tenacity of the cut thread wire that is being forced into the hole; determines the amount of volume below the full thread depth that will be required in order not to break a spiral point plug tap.
The vast number of formulas and advice found in articles and training manuals would assure the breakage of the tap in any material other than plastic, cast iron, lead, or aluminum. One method would be to use the values found in training manuals and/or tap catalogs, and when the tap breaks; increase the tap drill depth until the tap stops breaking.
Most would suggest other threading methods rather than answer this question; however, the fact remains that if it is hard material, using a spiral point tap remains the most cost effective operation for producing a thread.
For 2 x diameter depth threads: Thread Depth + Thread Pitch * 9
For other Thread depths: (Thread Depth * (1 + Thread Pitch * 4)) + (Thread Pitch * 9)
This will result too much tap drill depth in large diameter fine pitch threads; however, in the absence of any real scientific imperial data based upon the volume, stiffness, and tenacity of the thread, “chip”, wire being forced into the hole based upon the science of material chemistry and hardness, it is the best that anyone will give you.
