Tank Settlement Survey
Whin
5
Is it necessary to perform a routine soil settlement survey for in-service tanks that are supported by concrete ring wall, or is this requirement applicable only to tanks that rest on an earthen foundation (without ring wall)? Could someone provide a relevant reference standard for this requirement? Thanks in advance...
Refer to API 653 , Appendix B which is normative.
Evaluation of Tank Bottom Settlement
B.1.1 ...... During operations, settlement measurements should be taken at a planned frequency, based on an assessment of soil settlement predictions. For existing tanks that do not have initial settlement data, a program of settlement monitoring should be based on prior service history.
The monthly routine in-service inspection shall also include a visual inspection of signs of settlement.
"Necessary "? Not really, but depends on what the ground situation is and whether there are any visual clues that settlement has occurred.
And foundation can settle or subside given poor ground conditions or undermining by e g. water flow
Settlement survey was taken during hydrostatic test after tank construction, subsequent external visual inspection (5yrs of service) doesn't shows any signs of settlement. Is it mandatory to have another set of settlement survey as planned frequency?
"Mandatory" implies legislation so no, but would seem to be a good thing to do a 5 or 10 yearly basis. Really doesn't cost that much.
My points are ;
- The settlement measured during hydrostatic test is immediate settlement . Time dependent Consolidation settlement is totally different story. Depending on the soil conditions , ( for normally consolidated clayey soils with high GWL ) the consolidation settlement may last several years . Sometimes 30 years .
- The standard says ( ....During operations, settlement measurements should be taken at a planned frequency, based on an assessment of soil settlement predictions....) . That is , the settlement analysis is a prediction only and for settlable clayey soils if you can predict with in an error of 20 % limit , you are lucky.
- Again standard is clear . Look to the soil data, geotech report and settlement prediction calculations , initial test settlement and past inspection reports and decide accordingly if new survey and a program of settlement monitoring should be necessary.
( P.S. Settlement in MEXICO CITY at some locations was several meters ).
