SJEC
Petroleum
- Jun 21, 2004
- 41
I am working on a old tank built in 1975 and have problems on tank overturning calculation.
Before asking the question, I search the website and found following discussion.
However, I still have some questions about it. I appreciate any advice.
1. Per latest standard API 650 API increase the wind uplift pressure from 15 lbs/ft^2 to 30 lbs/ft^2 since 2005.
Should I use the new standard or use the as-build standard?
2. The tanks is structure supported roof tank. During the calculation MDL . My understanding is we should account whole roof weight. However, the software e-tank only use the weight supported on the shell (particular weight supported by the structure), which one is correct?
