I am scheduled to do a tank inspection at an asphalt plant in Florida. The tanks are vertical single wall ASTs (20,000 gallons). The pictures I have been sent of the tanks show that the tanks appear to have been dropped on the ground and dragged and hit with a loader and various other abuses. The tnaks are currently in service containing diesel fuel. I plan to use an ultrasonic thickness gauge on the exterior of the tank shell and roof, taking measurements at regular intervals and also in badly corroded areas. My questions are:
1) What is the best and most correct / safe way of removing rust and paint to take measurements on the damaged areas?
2) Will it even be possible to get measurements on rusty dents and gouges?
3) Is it appropriate to utilize a man-lift that close to small diameter (10-12') tanks? Do I need fall protection?
4) Am I approaching this the corretc way?
The testing is being undertaken to satsfy SPCC and corporate audit requirements. The tanks are in contianment and under a pole-barn type steel roof structure. Any recommendations or experiences from you all would be greatly appreciated. Thanks everyone,
Chris
Mechanical Engineer
Fuel Farm Deisgner
API 653 Inspector
Chris
Mechanical Engineer
Fuel Farm Deisgner
API 653 Inspector
