JDN
Chemical
- Dec 21, 2001
- 4
Hi
I'm in the process of sizing up a tank coil for heating heavy viscous crude. I'm targeting a temp difference of about 36 F. The tank is relatively large (5000 bbl)and once full will remain full as it is set up such that fluid entering the tank overflows to a second tank via an internal riser. Heavy crude is constantly entering the tank at a significant rate. I've done the math on heat duties and have selected a conservative overall U. I'm using a heat medium system at 385 F. My question is this. How can I take credit for the bulk fluid temp in order to reduce my required coil area. The way is stands now, I would require alot coil in order to accomplish the task. My gut tells me that if the bulk fluid temp is already at 176F and my incoming fluid is 140F, there must be some way to apply credit for the bulk temp. Has anyone come accross this before?
