We are a manufacturer of Christmas Ornaments. In the process of painting the ornaments, we have excess lacquer which collects on our equipment racks. We have a stripper tank containing hot water and caustic soda for cleaning. We have a boiler that was used for heating the stripper tank and 2 evaporators. The evaporators are off line now so it is overkill to heat just the stripper tank with a 750k BTU boiler so we are trying to cut costs and see if a commercial water heater could to the job.
The tank measures 12'L x 2'W x 4.5'H and holds about 840 gallons. 1" copper pipe comes from the boiler which is on a platform above the tank and about 100 ft away. We would tie into the pipe with a gas water heater about 15 ft above the tank. The pipe comes from above at one end of the tank and extends vertically into the tank along the tank wall. At the bottom of the tank it turns 90 and coils back and forth along the bottom. There are 6 runs 10' in length along the bottom. The pipe at the end of the coil then comes up out of the tank back to the boiler to complete the closed closed loop.
We need to heat and hold the water between 130 and 140 degrees 24/7. Could this be done with a gas water heater and what is the calculation to determine what size water heater we would need and any other changes to the piping, etc.?
Thanks in advance for your help.
