alienitmeca
Hello, i want to design a vertical tank for slug to produce biogaz, the probleme is the internal pressure may exceed 15 psig wich the maximum design pressure allowed by API 650
I need to know if there is another standard i can use in this case knowing that the pressure maybe close to 70 psig.
thank you in advance
