Tabular Note Issue 2
BrittToolEngineer
Aerospace
Greetings: I have a title block on my drawing sheet with a tabular note. There are data in the cells of the tabular note, but they do not display. If I double click on a cell, a window pops up showing me what is in the cell, but it does not display. Can anyone help me with this issue?
Thanks,
is the cell completely empty or does it display ### ?
If it displays ### NX considers the cell to small to fit the text. make the cell wider and the text should appear as expected.
Tomas
It does not show ###, but each cell does have a small box with an x in the box at the top left corner of each cell. I've tried resizing, but still does not display the text.
A small box with an x, i wonder if it might be trying to use a font which doesn't exist.
select the cell such that it is highlighted, ( not double click, single.) Then press Ctrl+I ( = Information - Object)
search the window for "font". Do you have that font in NX ?
Select the table and change the font for all cells.
Tomas
Tomas - Changing the font was the answer. Thank you very much for your help.
BW
