TABLES WHIT ORDINAL DIMENSIONS?
CORDVI
MX
I want a TIP to make a table with the values of the ordinal dimensions.
When I make a draw whit a lot of dimensions, the draw became unreadable. Thas why a put the values in a excel table, but i do that manually.
If anyone can't help me to do the same in better way, I'll appreciate.
Thanks!
Create a design table, with the ordinate dimensions.
You can then insert the desing table in a drawing.
Hope this helps.
Joseph
THANK YOU JOSEPHV.
THAT TIP HELP ME.
CORDVI,
I wanted to insert a dimension table on my fabrication drawing, but then I realized that there is no good reason not to insert multiple views on the drawing. This would be insane on a drafting board or in 2D CAD, but it works fine in 3D.
You can have one view for the 6-32UNC taps, another view for the cbore for M6 cap screw, another view to define a complex outline, etc.
JHG
