Table with repeat region
  • Thread starter Thread starter gkling
  • Start date Start date
G
gkling
Guest
I'd like to add some text to a table in a repeat region. When adding text to the table it gives me the message cannot modify non-template cell of repeat region and will only allow me to add text to the first row of the repeat region which I gather is a template cell. Can anyone help. Thanks, Greg
You can not have mixture of repeat region value and typed in text.
What you might do, depend on your requirement, is have simple repeat region on first column and have no repeat region on second column.
Use
Table > Repeat Region > Comments
You can add a cell to each line of the repeat region which will accept normal text (via Enter Text).
Make sure the comment cell is blank, then select it & add text as required to each line.
The comment cells will also move around with their own line when you fix indices, etc...
Ed
