Hi
Can someone give me an example or a situation that demonstrates the use of joint efficiency E=0.85 (spot) for type 1 category D joint (e.g. nozzle neck to shell corner joint) per table UW-12 ? In what situation would this be critical in design? Many cases, I only see nozzle neck thickness calc with E=1. When do we ever need to look at or use the joint efficiency of nozzle neck to shell corner joint?
