Hi Guys,
Currently I am designing a one way slab which has beams (T-beams).
We know that when the neutral axis is in the flange the beam acts like a regular (bf x d) rectangular beam (bf is the effective flange width). In this case if the calculated reinforcement ratio is less than RHOmin then we must use RHOmin to calculate the minimum rebar.
I remember from the school time (and also saw in "Winter" concrete design) where it says the bw (web width) must be used for min reinforcement calculation but here is the problem:
If we use the bw then the available flexural strength of the beam will be way lower than the demand. How this could be explained? Why we must use the bw for Asmin?
