Hi fellow forum members,
I am at a loss how to solve this issue. I developed an NX4 application and I am able to run this successfully locally. However, once moved to a server, a SecurityException is thrown.
I have done a lot of research but I haven't found a solution for my problem. I've tried to set the .NET 1.1 configuration on my computer and on the server but to no avail - I increased the LocalIntranet code set to FullTrust but it still does not work. Unfortunately I am not an expert how these security permissions work, only that something needs to be set, but I don't know what exactly!
An exerpt from my log file is below. I would appreciate any help! Thanks so much!!
AppBase: \\mrosmmf012\NX_4.0_Global\TDF_Tools\application\
Loaded assembly: System.Drawing, Version=1.0.5000.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a from c:\windows\assembly\gac\system.drawing\1.0.5000.0__b03f5f7f11d50a3a\system.drawing.dll
Loaded assembly: TDF_MIKRON_dwg_to_dxf, Version=0.1.11.2010, Culture=neutral, PublicKeyToken=null from \\mrosmmf012\nx_4.0_global\tdf_tools\application\tdf_mikron_dwg_to_dxf.dll
Loaded assembly: Microsoft.VisualBasic, Version=7.0.5000.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a from c:\windows\assembly\gac\microsoft.visualbasic\7.0.5000.0__b03f5f7f11d50a3a\microsoft.visualbasic.dll
Caught exception while running: Main
System.TypeInitializationException: The type initializer for "TDF_MIKRON_dwg_to_dxf.EntryPoint" threw an exception. ---> System.Security.SecurityException: Request for the permission of type System.Security.Permissions.SecurityPermission, mscorlib, Version=1.0.5000.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 failed.
at TDF_MIKRON_dwg_to_dxf.EntryPoint..cctor()
The state of the failed permission was:
<IPermission class="System.Security.Permissions.SecurityPermission, mscorlib, Version=1.0.5000.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"
version="1"
Flags="UnmanagedCode"/>
--- End of inner exception stack trace ---
at TDF_MIKRON_dwg_to_dxf.EntryPoint.Main(String[] args)
*** EXCEPTION: Error code 67 in line 996 of O:\ugnx404\ip2\src\syss\no\ind\lmldr.c at Tue Nov 30 23:51:34 2010 W. Europe Standard Time
+++ The type initializer for "TDF_MIKRON_dwg_to_dxf.EntryPoint" threw an exception.
version="1"
