HI Everyone ,
I have Gree Concealed duct type AC units , runing on R-410a , what are the working pressures for the 410a on the liquid side and on the suction side ( all tech have there own ideas what the pressure should be ) , how we come to a conclusion that the system charge is ok
the problem is that the units are not cooling at all ( thermostat set at 16-18C and room temp stays at 30-31C
the other day i took the following reading on a 4 ton ac unit
high side pressure : 250 psi
high side actual line temp near the indoor unit : 25 C
low side 150 psi
low side actual line temp on suction : 10 C
lets say i have a freshly vacuum unit i need to charge , what parameters should i be looking at inorder to now that chrage is ok ,
the unit have electric expansion valves
plus the outdoor unit have no details for subcooling and the mentioned opr/press id very high , * Attachment *
please advice
low side 150 psi
please advice
