I have a question regarding development of a system head curve. I've attached a basic example to help explain my question. If I have a duplex wet well and given a pump curve, I'm trying to determine the single and combined pump flow. My issue is in what system head flow do I use to determine this. In the attached simple example, I have it split into two pumping scenarios.
One Pump On: In this scenario, I've developed my system head using increments of 1x pump flow from pump, all the way through to destination. The blue curves represent my single pump curve and two pumps in parallel curve. My single pump flow is at point "A" and my combined flow is at "B".
Two Pumps On: In this scenario, I've developed my system head using 1x pump flow from "A" to "B" and 2x pump flow from "B" to "C". As with the scenario above, the blue curves represent my single pump curve and two pumps in parallel curve. My combined flow is at "D", but what would "C" represent where two pumps are on?
Which method is correct in determining my multiple pump flow?
I am assuming the x-axis represents the total system head (as opposed to the single pump flow)?
I've searched to the end of the internet and most examples are all based on my first scenario above, but they don't really explain the development of the system head curve if two pumps are on.
