Tracy,
How are you trying to use this function? Are you trying to add the current date to a drawing or a model parameter? In drawing mode the parameter &todays_date will pull the system date. The display characteristics of the date can be set in config.pro todays_date_note_format. The value would be something similar to %mm/%dd/%yy to control how the date is displayed.
