I am trying to develop system curves for a booster station that got destroyed during Hurricane Ida. We need new pumps as the old pumps were inundated with salt water and received some wind damage. I've read some previous posts that were very helpful about developing a system curve for a booster station where tank levels vary, which is the situation I am currently looking in to.
When doing so, my "low end" system curve is very low, i.e. 500 GPM @ 1.8 feet of head. This curve was developed based on a low flow event, downstream tank empty, and suction pressure at the booster station basically equivalent to the pressure at the downstream tank. I know the head sounds low, but keep in mind that we have 18", 14", and 10" waterlines in parallel feeding the downstream tank.
My "high end" system curve is 1 MGD @ 71 feet of head. This curve was developed on a high flow event, where the downstream tank is full, suction pressure at the booster station is at the preset shut off pressure of 30 psi, and water only goes through the 14" and 10". I did this because there are times where the 18" line is closed off so we can push more water through the 14" and 10" line to increase chlorine residuals.
I guess my main point in posting is trying to get some feedback from some experienced engineers on if you've seen situations like this? Is this wide of a range for the system curve common for booster stations?
