Syntax message
CATPart
Automotive
Jun 12, 2006
115
I have a part (R14) that after using SMARTVOLUME in one formula I receive below message, (only the first time that I open this part in session).
Formula is very simple smartvolume(pad), so I think that shouldn't be any errors in the formula.
I would like to know the meaning of this message?
Rgds,
Damir
Load the Knowledge Libraries as shown below. These are not loaded by default.
my.php
I used the same formating as you
The imageshack gives you few links, have you used the one below:
Embeddable Code: + forums
Damir - Tools - options - General - Parameters & Measure - Knowledge environment - load all
Derek
