While looking at synchronous modelling, I've found some great uses for it, such as:
- editing features in an un-parametric (imported) CAD model
- creating machining operations in a machined casting (i.e. linked in casting, then machine it)
- edit complex parts (several hundreds of features) where normal editing will not work
- editing parts where design intent does not allow you to make the changes you need
All of these are methods for editing existing parts, and record the changes made as features.
I've also found that synchronous commands can be used as normal parametric modelling features.
Typical examples would be replace face to change a shape, or rotate face to change its angle.
BUT
I've also seen a lot of models almost built entirely using layered synchronous commands, and these are awful.
They're hard to understand, difficult to edit and just plain messy.
My question - does anyone know of a freely available training guide to good and bad use of synchronous modelling that I could distribute, to save me the trouble of re-inventing the wheel?
Thanks in advance, Carl
NX 8.5 with TC 8.3
BUT
NX 8.5 with TC 8.3
