Mahmoud-Abdullah
Dears,
I have a required sequence of operation in a power center switchgear. The client have 2 transformers, 2 generators and bus coupler.
Each transformer and generator for each section.
In normal operation, each transformer is feeding its section and bus tie is off. if one of transformer is out of service, the bus tie will be on.
if two transformer are out of service, 2 generators starts automatically and feeding its section.
The question is:
The client needs not to cut the power supply when the transformer get back healthy. Is it applicable to synchronize a transformer with a generator?
If yes, what is the devices required to made such scheme?
Thanks,
Keep Moving Forward
The question is:
Thanks,
Keep Moving Forward
