kitloke77gmail
- Mar 9, 2013
- 3
We need to synchronize an 11kV voltage source with one 415V source. Attached is a simple sketch of connection diagram.
In order to have the synchronization done at 415V bus, I need to first step down the 11kV source to 415V. Can I use the same transformer to feed the 415V supply back to the 11kV bus after synchronization?
Can I use a YNyn transformer so that I can first step-down the 11kV source to 415V to give supply to the 415V Generator Auxiliary (three phase with neutral, connected to the same 415V bus) to start up the 415V generator and then use the same transformer to export the 415V supply to the 11kV bus?
