Swing Check Position?
Budro
4
I have a 1500# steam swing check valve with no external indication of the open or close position of the check. Does anybody know if there is an external/clamp on device that can determine the position of the check without modifying the valve (ASME Boiler valve)?
To determine if it is moving you can use a stethescope. If you have a good ear you should also be able to differentiate flow from no-flow. Beyond that the only ongoing indicator I can think of is a strap-on ultrasonic flow-measurement device.
David Simpson, PE
MuleShoe Engineering
Depending on the make of the check valve, for years I have simply scribed a line on the clapper shaft relative to an external reference point to show "CLOSED". Obviously when the valve is OPEN, the line is misaligned.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
I wish this was the case, but the swing check shaft is completely enclosed in the body of the valve. We also need to the position prior to any flow/process moving in the pipe. The only thing I can think of is X-ray.
Jeff
If you applied an alternating magnetic field across the valve, parallel to the check shaft, say by means of a C- shaped armature with pole pieces near the valve seat, you might be able to measure, say with a linear output Hall effect device on one pole, a change in the valve's magnetic impedance (reluctance?) depending on whether the poppet was in the seat or not.
I'd expect a small signal, and you'll probably need to also measure the temperature so you can compensate the LOHED.
-Mike-
