Swiftpipe/ZapLok Pipeline Joint 1
CJLW
Petroleum
Does anyone out there have experience of Zap-Lok pipeline joints? The vendors promote the good points of course, but why haven’t more operators taken up this technology?
Grateful for your thoughts
When I asked this same question at a company I used to work for I was told that they were generally leary of mechanical type joints. After I worked there for a while I found out more about why. They had a line that was put together with dresser couplings (compression couplings) and over the years had experienced some problems with them, mostly seals drying out and leaking.
In my opinion, and take it for what it's worth, ZapLok or other similar systems are alright for systems that are expected to have a fairly short lifespan, but for systems that are expected to be around for the next 100 years its probably better to go with a butt welded line. I don't know exactly where I'd draw the line of "short lifespan", but my gut feeling is somewhere around 10-20 years. Maybe in another 100 years we'll look back and still have ZapLok pipelines in service, time will tell.
Previous comments aside, I have heard good things about the current ZapLok systems and I've seen them installed in gathering situations several times, but I haven't actually used it on any of my own projects. An advantage that a product like ZapLok has over a dresser style fitting is that the epoxy used for the seal doesn't dry out like a rubber seal will so as long as you don't disturb the joint once it's in place it shouldn't leak.
Patrick
Thanks for your reply, like you I am concerned about the use of mechanical joints and I'd need to see it in service (on real projects) for quite a while before I'd buy into it on a hydrocarbon pipeline.
I wonder if they have taken account of installation stresses, soil movements and the practicalities of manufacturing these joints in the harshest of environments with available labour resources - you can make almost anything work in a laboratory but on a pipeline spread, that's another matter....
I did some desktop study on this zap-lok few months ago, and I realized that it has been applied widely onshore (mostly in US). For offshore, not much I knew, but some are there. But they cannot apply the offshore pipeline with concrete coating.
Pls noted that this is only desktop study and correspondence with the vendor itself.
For comparison, you can also look for Zap Lock, almost the same mechanical joint, but with friction coupling.
